Brakes feel spongey after overhaul
Old Nov 4, 2010 | 11:46 AM
spetz's Avatar
1994 E220 Coupe
I just got:
-Zimmerman front rotors (left rear ones standard)
-Textar pads all around
-New brake lines front and rear
-Brake bleed
However, the brake pedal travel is quite long. The first inch or 2 of travel does nothing, and then they grip. They grip fine but towards the bottom of the travel.
The mechanic said this will become normal after a few days of driving.
Is this true? Does it take a while for new brakes to work well?
Old Nov 4, 2010 | 11:59 AM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Originally Posted by spetz
I just got:
-Brake bleed
Typical of bleeding not done properly...
A hydraulic system will not change for the better over time..
Either works properly or doesn't...
Was your system drained and flushed and filled with fresh fluid ?
Old Nov 4, 2010 | 12:02 PM
spetz's Avatar
1994 E220 Coupe
I don't know exactly what was done however I paid for 1.6 liters of brake fluid
Old Nov 9, 2010 | 03:58 PM
slow_vw's Avatar
w124 OM606
sounds like it needs to be bled again...
fresh pads will feel like theyre not biting very hard for the first couple days, but the pedal should still be firm regardless
