93 300D wont start after Fuel Filter change...
changed fuel filters today, after changing, turned key on, let fuel run, then started car, ran for 3 seconds then gagged and died...i beleive that there is air in the lines, how do i bleed the system so i can start my car???
thanks...
Mario
1993 300D...602 engine
thanks...
Mario
1987 Mercedes 300D Turbo
Hmm...
I think the first time I changed my fuel filter I had to crank it for about 20 seconds before it started and stayed started.
Ever since then I have used diesel purge when I change the fuel filter and I fill my filter up with that after I change it and then run a can through my engine.
It works pretty well, and I don't have to worry about that empty fuel filter making me crank my engine for a long time....
-Jared
-Jared
E300 TD Avantgarde 210
the best way is fill up the new filter with clean fuel b4 fitting
fill the new filter through the outer holes so the risk of contaminants reaching the fuel pump is reduced.
Mercedes diesels are self-priming/purging.
You may need to crank the engine 30 seconds or more.
Check the manual for more details.
(If you crank for 30 seconds, be sure to stop for 2-3 minutes, to let the starter cool down, before cranking again).
It will eventuall prime & run fine.
(Been there done that - bad fuel gauge in '87300TD)
