w124 hesitate to accellerate
Old Dec 17, 2010 | 03:07 AM
kingclassic's Avatar
w111 w124
Angry w124 hesitate to accellerate
hi everybody,
my car hesitate to accellerate!she do ok with new sets of spark plugs but after a few day the same problem arise again!
Me car is a 91 model with EZL ignition system.I have replace auxilliary idle valve,fuel valve,overload relay.
fuel pump,fuel relay tested ok.please help!!!
Old Dec 17, 2010 | 03:42 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
Rotor and distributor cap? What about spark coil?
Old Dec 17, 2010 | 06:57 PM
w111 w124
rotor arm renew as well and distributor cap checked.sometimes the motor fluctuate during idling.sometimes it fluctuate when the air conditioning switched on.when decellerate the engine stall!!
Old Dec 17, 2010 | 08:35 PM
Quicksilver500's Avatar
1992 Mercedes-Benz 500E
Could be an injector that has a bad spray pattern. New plugs might ignite something real rich like that. Was the fuel distributor real dirty on the inside?
Old Dec 17, 2010 | 09:49 PM
w111 w124
hi,
tested the cold start valve,it works fine.the air flow sensor and everything in there is clean.injector spray pattern?how to check it?
me workshop manual did mention "only a small amount of fuel should
be visible"after building up fuel pressure and i depress the sensor plate.
but how small?i notice fuel flowing when i push down the sensor plate.
please help me!!!
Old Dec 17, 2010 | 10:06 PM
ryanpro50's Avatar
w124
depending on what motor you have, they are horrible for valve guides wearing out causing plugs to foul. Is there a burnt oil residue on the plugs? what do the plugs look like when you pull them out?
Old Dec 17, 2010 | 10:41 PM
w111 w124
motor is good!no sign of burning oil.the plugs are all light brown!after a few trip the spark plugs produces slightly reddish spark!I know over fuelling could kill a spark plug.but at which point of the fuel system?
fuel distributor which holds the control plunger and seals are the only place i havent check.As i say,the amount of fuel flowing after i build up the fuel pressure should be how small?
flowing?or vapour only?
