1991 300D 2.5 Turbo: Shakes violently
Old Feb 17, 2011 | 06:16 PM
Fox McCloud's Avatar
1991 Mercedes-Benz 300D 2.5 Turbo
Exclamation 1991 300D 2.5 Turbo: Shakes violently
I have a 1991 300D 2.5 Turbo; functions fine, normally, but I ran into quite an issue today.
When I took off, I put my car into reverse...then began backing up, I heard a loud "CLUNK"; when put it into drive, the car began shaking violently--naturally, I stopped, at this point.
After letting it idle or a bit, I shifted it back into reverse (wasn't actually moving, just shifting it into reverse); it began shaking violently again; I tried again, only in drive, only to experience the same results.
When put into park or neutral it doesn't behave in this way---the engine sounds fine and runs like a top, as always.
Any ideas what the problem could possibly be?
Old Feb 20, 2011 | 08:46 PM
Exclamation Update
looks like it's the front flex disk that broke---now it's just issues with getting the front portion of the driveshaft out (rear portion is out) without removing the exhaust system.
Old Feb 23, 2011 | 10:13 PM
CCMcC's Avatar
1993 300D
Yikes...
I just had mine replaced. I hope this isn't too hard for you to fix.
