Replace vibration dampener?
Old Mar 15, 2011 | 01:29 AM
Fox McCloud's Avatar
1991 Mercedes-Benz 300D 2.5 Turbo
Exclamation Replace vibration dampener?
Recently the front flex disc on my '91 300D 2.5 Turbo failed--when it was off I noticed that the vibration dampener on the drive shaft had a few cracks in it--is this normal and should it be replaced? If so,does anyone have any recommended sites on where to get this?
Old Mar 15, 2011 | 10:19 PM
matsalleh76's Avatar
1986 190e 2.3-16
Drive shaft vibration damper: remove it and do not replace.
When the rubber begins to show cracks it will not be long before it disintergates with a great bang and the loose outer ring tears up the underside area as it thrashes around and earns the car a guaranteed tow home.
It does nothing and was factory deleted from later models. Toss it.
Regards,
bobf
