# 3 Fuse Keeps Breaking...
Old Apr 16, 2011 | 09:52 PM
SNSMBZ W124's Avatar
'92 300E
Question # 3 Fuse Keeps Breaking...
Hi everybody!!
Problem: Fuse #3 (parking/tail light right, headlamp cleaning unit, illumination: license plate, instrument panel, controls) keeps breaking every time I turn on the headlights.
Anyone had this problem or might have an idea of why this is happening? I noob like me would love to know!
Thanks!!
Old Apr 17, 2011 | 12:04 AM
'92 300E
starting to think it's the headlight switch shorting out.....
Old Apr 17, 2011 | 04:19 AM
Shoomakan's Avatar
2006 C55 AMG 6 speed
Ahh, Mercedes electrical gremlins. My front window fuse would blow up to 3 times a day, and I never knew why. Carried a candy case around filled with fuses.
Then one day it just... worked. :P
Double check you have the appropriate fuse amperage, and do NOT attempt to rectify the situation by adding a stronger fuse. Remove your headlight switch and take a volt meter to it, I guess.
Old Apr 21, 2011 | 01:55 PM
124-Fan's Avatar
Mercedes Benz
I would open the trunk and inspect the wire loop attachecd to the hinge. Pry open the covering and intspect the wires. Common fault.
-Cheers.
Old Apr 26, 2011 | 08:33 PM
larryj's Avatar
2004 SLK 230, 1992 300E & 400E
Access the headlight switch...........
..........with a multi-meter. Check the headlight wiring from the switch to a chassis ground.........each wire, individually. If you have continuity then you have a shorted wiring harness (and, yes, check the point where the hinge is, but, if, instead, it is ONLY blowing the fuse when the headlights are switched, as opposed to blowing the fuse when the parking lights are turned on, then it would not be the trunk hinge point for the license lamps).
Enjoy!
