Problems with climate control system
Take a 1cm x1 cm piece of paper and place it over the vent up in the overhead light switch. If it sticks there, you have ruled out a bad aspirator or sampler motor, which pulls air through that vent across the interior temp sensor. If the paper falls off, then that little motor under the right dash vent in the dash is not sucking air, and the temp sensor gives a signal for full heat, then full cold, etc.
Is the charge of r134 refrigerant correct? If not, the compressor won't run. When you do not have cold air, did you look at the compressor to check if the clutch is even engaged? That "AC relay" he refers to is called the Klima relay, which controls the compressor engaging on. Not all 124 cars have it- that function was wrapped into the MAS control unit for a few years.
There are other things to check before buying a reconditioned Climate Control Unit (the pushbutton unit), about $250.
Pull the instrument cluster, and there is a six pin connector behind it, just to the right of center. Contacts are bad in the connector - you can either just try to clean them out, or replace the connector (the dealer can get you a brand new one if you want). Same symptoms as you describe - CC not functioning correctly, and A/C blower speed is not working
You might also look at the harness under the fuse box.
1. When I first start the car. The climate control will work fine. After about 1 or 2 vminutes the screen would go blank. Nothing works. Then the fan under the hood would come on and stay on.
If I let the car sit and repeat the process. It would work again for another 1 to 2 minutes.
The AC works fine as well as the heat until it loses power.
Any help would be appreciated. Thank you.
