Carbon Fibre Parts
e400
Carbon Fibre Parts
Recently I've been considering making some of my own carbon fibre parts. I've done some research and it doesn't seem too hard to do....once you have the mold.
The mold seems like the hardest part to make, and I don't really understand it completely.
So to make the mold, do i just take the piece im looking to make carbon fibre off the car and craft a mold using that?
It seems like an easy but time consuming DIY. Anyone have any advice on how to make the parts or the mold? Or maybe what not to do?
e400
Bump.
No one has any advice for the carbon fibre?
Sometime next week im going to attempt to make some of my own real carbon fibre parts.
And if i make them sucessfully i may be able to make some parts for anyone who wants them.
Would anyone maybe be interested in some CF parts if i can make them well?
CF work isn't cheap, and it isn't easy.
That being said, if you're actually good at it sure, I may commission you to do something eventually. But I'm picky, the parts would have to be damned near perfect.
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
The mold seems like the hardest part to make, and I don't really understand it completely. So to make the mold, do i just take the piece im looking to make carbon fibre off the car and craft a mold using that?
The mold is the easy part as it's taken from the part you're trying to replicate..
The hard part is laying up the fiber, be it very expensive carbon fabric or basic fiberglass...
Very difficult if the part is meant to be structural.
If you've never laid up or worked with fiberglass then not wise to start with CF....
The techniques are similar, but the CF material is much more expensive.
Do some research...find the cost of fabric and the required resins to make a part..
Just get some 3M DI-NOC and wrap your parts...you won't know the difference..
'91 C124 300CE,'06 ML 500 W164, '00 BMW MCOUPE, '65 COBRA REPL.
I'm with the above guys on this.
I have actually attempted to do this. I bought the fiber, the resins, did research etc.
Failed!!!
It is very hard, very labor intensive and you need to have the knowledge. With patience and money one can succeed, but a bunch of money will be required for the failed parts.
If you do want to attempt it, ebay has the stuff you will need.
I attempted to create a flat large piece as an experience, it turned out OK, but not perfect. If it is not perfect it is not going in my cars. I was attempting to make parts for my Cobra.
In my 300CE I went with 3M dinoc as suggested by Ed and am very happy with the results.
Here is my interior. I covered the cracked wood with it. Very cost effective.
Failed!!!
e400
Well I've looked up all the stuff i need and i can probably pick most of it up from stores around my area, except the Carbon fibre.
I know the CF is pretty expensive, but i was going to start with small, basic, flat parts until i get the hang of it.
I've done some fiberglass stuff in the past, mainly just repairing it but it doesn't seem to different to me.
I've got the time and enough money to make some parts so i don't see why I can't do it, or atleast give it a shot.
The best CF makers in the world had to start somewhere...
As long as im careful with the outside layers i think i should be fine. The inner layers still have to be decent but they won't be seen. I figured i can just take as much time as i need on the outside ones then speed it up on the inside layers as they wont be seen.
Right now im still trying to hunt down the most basic small part in my car that I can start with.
EDIT:
That wrap turned out pretty nicely but im going for all of the benefits of the real carbon fibre. Weight isn't really a big issuse because im only going to be doing small pieces but its about the same strength as still which i find very beneficial.
Also i like the very glossy finish of carbon fibre. The wood on the W124's kind of has a glossy finish aswell, so i think it would look great with real carbon fiber.
Any ideas???
EDIT:
Any ideas???
Everything has to be compatible, it's not random.
http://www.eastbaycomposites.com/
http://store.carbonfibergear.com/car...Fcbc4AodnA0liQ
What are you making your mold from?
Any ideas???
Any ideas???
1 Post
W124 E Cabrio, 997 Porsche cabrio
The most important thing will be how clean & strong your molds are. After that, you will have to practice on getting the carbon to lay down in the mold w/o damaging it & avoiding air pockets. I've been doing this for the past 12yrs & till this day I still hate doing exposed carbon. I've done several 124 wood trim replacements. I have a few pix on my web-site if you want to get some ideas to help you out. www.SoCalCarbon.com
Kind regards,
A.S.
Kind regards,
A.S.
