wiring harness interchangability
Old May 14, 2011 | 10:49 PM
lsboogy's Avatar
2002 CLK55, 1993 190E, 1975 230C, 2007 E350
What wiring harness' will fit a 95 E320 (M104) - my daughter's engine harness is starting to have problems, and I find the new ones are 900 bucks, and I see a bunch on evilbay for various prices. I am thinking about using a 93 E300 wiring harness - will it work, or what should I do - is there no substitute?
Old May 15, 2011 | 12:46 AM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
Isboogy -
Funny you should post this as I just changed my harness today (about a 2 hour job).
For USA M104 cars there are two wiring harnesses, the early harness, MB part 124 440 56 32 and a late harness, MB part 124 440 29 33. They are not really interchangeable and both are expensive, although the earlier harness seems to be a little cheaper.
The early version is often described as the "round" thermostat sensor plug version while the later version is known as the "square" thermostat sensor plug version. I believe the difference is because MB went to a single unit dual ECU and HAVC coolant sensor on later cars while the earlier version had two discrete sensors for each function.
While the number can, in theory, be determined from MB EPC look-up and from looking at the connectors, the most reliable method is to check for the part number on the harness itself (this is particularly important if your car is near the change-over point). This is located on a label attached to the harness where it passes behind the battery.
Upon closer inspection of my old harness, I was shocked that my car still ran given the condition of the insulation.
Hope this helps and good luck.
- FD
Last edited by Floobydust; May 15, 2011 at 10:22 AM. Reason: Fixed a few typos from posting at 1 AM . . .
Old May 15, 2011 | 08:53 AM
joef's Avatar
S500
what is the part number of the harness you're after?
Old May 15, 2011 | 01:54 PM
lsboogy's Avatar
harness number I'm seeking
124 440 29 33
Old May 15, 2011 | 07:53 PM
deanyel's Avatar
400E
That's the later, more expensive one, about $800 at parts.com. The 93 is the earlier one and won't work. Rebuild the old one, used one, or $800 for a new one are your only choices.
