how to change shift selector knob?
I don't want to break my current selector knob by twisting it if it doesn't unscrew. Could someone please advise how to change out the old for the new gear selector knob?
Thanks!
\QUOTE]To remove the knob. You must remove the gear selector rod as well. Simply remove the wood around it. Remove the plastic around it remove the gear indicator cover. (all this is simply pulled off). Then unscrew the rod nut. And your done.[/QUOTE]
This means that you need to buy the model update selector.
