c36 engine swap
Old Jun 5, 2011 | 11:21 AM
geosss's Avatar
300ce w124
c36 engine swap
hey guys, so you know i was about to do the 500e engine swap but got knocked down by the price, plus the car i got for the project was in to good of a shape for being to apart. now she serves a respectable mb lover, Steve in Houston (which i'm still keepin an eye on, from time to time to see how he treats her
and because of numerous suggestions of the c36 amg swap beeing the easiest, i got my self into that now, but i found out that it is not that easy either.
talked with different shops, and all of them say the same thing, different year, different model, a total different story, everything has to be changed, engine, ecu, whire harness.
so i don't know what to think.
the car i got is a c36 amg 97, is the easy swap "just plug and play" for the 94 c36 only or it applies for all the c 36, regardless the year.
i have on it the 5 speed trans, auto, so i was thinking of that also.
so do you have any thoughts ? do you know anybody that did, it literally, i'll die to talk with somebody that did this swap.
please help me out.anything you know helps me make the decision.
here is some pics of the c36
Attached Thumbnails c36 engine swap-01272011940.jpg   c36 engine swap-14523151_4x.jpg   c36 engine swap-14523151_3x.jpg   c36 engine swap-14523151_2x.jpg
Old Jun 5, 2011 | 11:26 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
Its only plug & play on the w124 if you have the 94/95 w124s as they are HFM like the C36.
No engine swap for an AMG engine (except the 500e engine) is plug & play on the earlier w124s.
Old Jun 5, 2011 | 11:34 AM
geosss's Avatar
300ce w124
ok, but the c36 i have is a 97, so will that change the story? and my coupe is 93 with the m104
Old Jun 5, 2011 | 01:46 PM
Shoomakan's Avatar
2006 C55 AMG 6 speed
If you have the parts car, you have the easiest job. Just remove everything from your car, and replace everything from the donor car. :P
Old Jun 5, 2011 | 06:53 PM
chlippo's Avatar
300E W124, 300E W124 3.4 AMG, Audi S3 2002
i am tempted by a similar project too. but my car is not an HFM so it will be a lot harder.
I might consider an M117 engine out from a 560 SEL but i didnt check what have to be changed to get that in place of my 3.4 AMG. I also not convinced to ruin a rare authentic car as mine, but it isnt fast enough for me (until now...still working on getting it 100% performing)
Old Jun 5, 2011 | 07:29 PM
ShoreBenz's Avatar
There is an interesting write up on this swap
in the Mercedes-Benz E-Class Owner's Bible: 1986-1995.
Old Jun 6, 2011 | 11:27 PM
bsmuwk's Avatar
Depends on the day
The 93's have HFM too.
Old Jun 7, 2011 | 02:47 AM
Shoomakan's Avatar
Hey Chlippo, are CIS systems interchangeable? If I drop a CIS M119 in there, would I need to change my wiring harness and stuff?
Old Jun 7, 2011 | 05:40 AM
1990 300ce 24v I6
All 93s or late production? AFAIK, 93 was not the switch over to the HFM m104
Old Jun 7, 2011 | 09:22 PM
ShoreBenz's Avatar
I believe 1993 was the transition year to HFM on both the 2.8L & the 3.2L.
The 2.8L engine being available just one year in the U.S.
Old Jun 8, 2011 | 01:35 AM
chlippo's Avatar
Nop you will need pretty much everything! EZL, MAS and all the electronic stuff. I was looking in Lebanon to buy a whole mecanical/electrical front end of M119 car, but didnt find a good deal! when all the parts are there, its an easy job.
Old Jun 8, 2011 | 01:47 AM
Shoomakan's Avatar
Ah well. I'm currently looking for an E320 engine to drop in instead of mine. Figure I could use the extra 35 ft/lbs of torque, and finally having full EFI will be a bliss.
Old Jun 8, 2011 | 01:32 PM
chlippo's Avatar
for that engine too you will need all the electronics too!
but once you have all those...you can drop a 36 engine...so i dont see the point of going E320 while for a bit extra you have the 36
Old Jun 8, 2011 | 04:45 PM
Shoomakan's Avatar
Because I want to boost it later. The 3.6 isn't boost friendly, and is much more expensive to repair...
Old Jun 8, 2011 | 09:45 PM
Brau0318's Avatar
Mars Red 2005 C230k, 2001 E320 4matic
I'm new to Mercs what exactly is HFM
Old Jun 9, 2011 | 05:35 AM
1990 300ce 24v I6
I believe it stands for Hot Film Media, its just a different engine control system than the CIS-E
Old Jun 9, 2011 | 06:52 AM
Shoomakan's Avatar
HFM is "modern" EFI, whilst CIS is neanderthal MFI.
Still, it's better than the electronic carbs that were popular for a while. The TBI system on GM cars, for example. :P
Old Aug 12, 2011 | 01:42 PM
MarioC55's Avatar
2005 C55 AMG Silver Bullet
so my car is a 1995 m110 Estate wagon... though how do i know if its 12v or 24v?
hmmmm...
so are you saying i'm better off boosting my estate wagon .... or doing an engine swap...??
how much if my stock engine from the e320 worth if i pull and sell??
curious...
mario
Old Aug 12, 2011 | 04:06 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
hmmmm...
curious...
mario
M110 was an old six cylinder from the 70-80's
You have a 1995 E320 which would be an M104-24V 3.2L I6...
If you don't know what kind of engine you have then you are not a candidate for boosting let alone swapping.
You have to have some basic knowledge of what you are starting with or else you will spend much time and even more money and end up with no so good results !!!!
Old Aug 17, 2011 | 10:46 AM
MarioC55's Avatar
when it comes to w124 i am some what a newb
Recently sepnt some years doing water cooled V-dubs... so 8v 12v 16v 24v are easy to spot under a volkswagons bonnet but a mercedes... well..
could only tell you about my old C55 engine bay :-D !!
And did i tell you about my VRT project for my Vr6?
hmmmm this guy... probably doesnt know a diverter from a blow off...
thanks for being so kind with your words... show off...
ohh and by the way your signiture looks like a fat womens rear end...
Old Aug 17, 2011 | 12:18 PM
Shoomakan's Avatar
He wasn't really showing off, you displayed a complete lack of information and interest in your car beyond the childish way of wanting to make it go faster.
You didn't know if it was a 12 valve or 24 valve? Without even searching google, had you just wiki'd E320 it would have told you that it was a 3.2 litre 24V engine, codenamed M104, making 220 horses and 235 ft/lbs of torque. It would have taken you 2 minutes. Not even.
More importantly, had you searched this particular forum you would have found (in my thread, no less) info that states that you can simply remove you engine, replace it with the 3.6, and just change the ECU. You're welcome.
A VR-T project is quite simpler than an E320 T project, due to the commonplace nature of it. There are a relative handful of people in the world who've successfully turbo'd their W124's, and you basically insulted one of them. Great going.
And yes, his car does look like a fat women's rear end. And it's gorgeous.
Old Aug 17, 2011 | 12:52 PM
DanielSL's Avatar
04' CLK500, 04' SL55, 01' S600, 90' 560 SEL / 560 SEC, 87' 560 SEC AMG, LR SIIa, LR DII.
Shoomakan;
Kudos to you. That was a beautiful reply.
Old Aug 17, 2011 | 02:52 PM
RBYCC's Avatar
I guess you are correct...difficult to look at a Merc cam cover and see if it's narrow holding one cam or wide holding two...
Don't really know much about turbos either..because my twin T2's don't use a blow out or diverter just have internal wastegates..
Ooohhh you had a C55...Me just a lowly G55K and CLK63 Black Series...
As far as performance I was going much faster then you have gone long before your beginnings dribbled down your father's leg...
Being a newb doesn't mean you have to act like an **** clown...
Pay attention and you may learn something from any number of "show offs" on this and other forums
P.S.
Here is another view of the fat ladies rear....even breaking your piggy bank would not allow you to afford this replica C124WB build...
Old Aug 18, 2011 | 04:36 AM
the_widebody's Avatar
124 320ce amg widebody twin turbo, the nail
the know alls level of arrogance seems to be multiplying, and the pilot fish are growing in character.
for any newbies a word of warning;
wow betide anyone who commits any of the following acts;
spelling mistkes
grammatical, errors
misunderstanding
questioning the ideas of the major league
not owning enough mercs, or expensive enough mercs
any other miscreant act against the ways of the elite
as a side note, it is also a 'fact' that an individuals skill is judged by how many cheques a person can write, and who they can find to do the work for them.
Old Aug 18, 2011 | 07:15 AM
Shoomakan's Avatar
Originally Posted by the_widebody
the know-it-all's level of arrogance seems to be multiplying, and the pilot fish are growing in character.
For any newbies a word of warning;
Woe betide anyone who commits any of the following acts:
spelling mistakes,
grammatical errors,
misunderstanding,
questioning the ideas of the major league,
not owning enough mercs, or expensive enough mercs,
any other miscreant act against the ways of the elite.
Fixed some of it. :P
Come on, dude. ALL, not half the info he requested is available in our very forum. And in the many forums I've been a member of, every time somebody creates a useless thread before searching the forum and/or chastising another member is treated accordingly.
While I honestly wouldn't have replied the way Ed did, I do see where he's coming from.
If I had posted what I thought is 'fact', ie not even knowing my own car's motor code and basic history, I would have not been surprised at any negative responses.
More importantly, put yourself in a situation where an up and coming person asks to make his car go faster when he obviously doesn't even know what it is, and then berates you for pointing that out.
I've said this in my earlier post, but will say it again, man.
If you've got an E320, it's a simple matter of removing your engine block and cylinder head, replacing them with the 3.6 units, and re-installing them. Then, just replace your ECU with the 3.6, or re-flash your ECU to 3.6 programming. I just wish you looked up that simple info before you started an argument.
If you're looking for even more power, here's a good thread with the inline 3.2 which you have.
http://www.peachparts.com/shopforum/...d.php?t=224975
That was the FIRST result in the search, by the way. :P
I'm sure if you do your research and contact Mr. Hughes, he'll also lend you a helping hand. If you have the money and time, I'd scour the interwebs until I found a Mosselman TT kit for sale and buy that. Least amount of fabrication, and you've got proven engineering and intelligence behind your setup.
