Always have to start twice to fire up
My 300TE always needs two starting attempts to fire up. It is very consisted in doing that.
The first start attempt sounds like it almost wants to fire up but then falls back in just cranking.
After a second start (or continue first attempt for a 3-4 seconds) it does fire up.
Every day the same.
Anybody an idea where this could come from?
when my rotor and cap was old it caused erratic running and occasional backfires.
2)check to see if the is any trace of green inside the cap and on the arm, if yes, then change/clean
The rubber fuel hose from the back end of the fuelfilter has a tendency to get soft and crack up after years of transporting fuel. If you got just a tiny leak in this hose the fuelpressure accumulator can't keep up the pressure, and you will have that exact problem that you describe above..
If the hose has got a hole it will drain the hose empty of fuel when you shut your car, and the fuelpressure will be gone. The short burst of the fuelpump on ignition will not be enough to get the pressure back up to its full.. Just a thought in hope to help you resolve your problem.
To ensure quick starts, fuel pressure must be available immediately upon cranking. To do this, manufactures generally do two things.
First, they maintain fuel rail pressure using the pressure regulator and a reverse flow check valve (see pic). When the car is not running, the regulator does not permit fuel flow to the tank via the return line and the check valve does let fuel leak back via the feed line. Failure of either will result in a pressure loss after engine shutdown. The regulator you know about. The check valve can be a separate component along the fuel line or can be integral part of the fuel pump and/or fuel pick-up.
Second, the fuel pump is usually run as soon as you turn the key to the first position before you turn it further to start the actual cranking. This helps compensate for any bleed-down that does occur. Note that for the pump to continue to run beyond approximately 2 - 5 seconds, the pump control circuit needs to get an "engine run" signal which only occurs after the engine is running and for some cars, during cranking. This is done for safety so that fuel does not spill through ruptured lines in an accident.
It sounds like your car is not maintaining or building fuel pressure fast enough. The proper way to diagnose this is with a fuel pressure gauge. MB provides a fitting to connect one so you can observe the pressure under the above conditions.
If you don't have access to a gauge, perhaps you should check the following.
On my M104 engine the fuel test point is a schrader valve. If you have then same, you can do a rough test for pressure. With the engine COLD, start it at let if run for about 15 seconds. Stop the engine and let stand for about 10-20 minutes then remove the protective cap on the fuel test point. Use a small screwdriver wrapped in an old rag to gently press on valve stem. Wear safety glasses and be aware that gas may spray in any direction (hence the rag). No need to drain the line, just verify if you have static pressure. The presence of pressure points to an electrical issue. No pressure = regulator or check valve.
Does the car take two tries on a re-start after the engine has recently been shut down? If so, this points to a significant pressure bleed issue.
Try turning the key on, but not to "crank" for 2 seconds, then off and immediately on again (but not to "crank"). Then immediately try to start. Does it still take two tries? If so, this points to an electrical issue (pump pre-start prime not occurring).
For what it's worth,
- FD
Last edited by Floobydust; Jul 21, 2011 at 06:05 PM. Reason: Added picture of fuel check valve
Finanily in front of my car, airfilter about to be taken off: "this car has electronic injection, silly me!"
Finally got back to this thread and saw a large amoutn of useful replies to my suprise. Thanks all!!
I will start with taking a look at the fuel hoose
the car does not need a second start when it has just been used. Although it does not start at the first crank but that is maybe to much to ask
i tried what you suggested, switch the key a couple of times to run the fuel pump. It still needed two starts (or a very long single start)
So, this could then be your suggested electrical problem. You can here the pump running. What is the 'pre-prime' you mentioned?
thanks
Most effective way to look for such leaks would be to turn the key to ignition for a few times first, then go under the car and look for wet hoses and smell for gasoline.. If there is no smell of gasoline present you could rule out a leak being the problem. Because the pressure by the pump would spray the fuel out of the tinyest hole, leaving a distinctive smell of fuel in the area.
And.. don't smoke while doing this!
Fuel injectors...ever taken out and cleaned or changed?
The checked stuff and could not find anything...yet
The also suggested injectors. As a start I have now got fuel cleaning stuff in my tank. Will see how that goes.
yesterday suddenly no starting at all, dead battery.
cause was a poor battery. Battery replaced and ....starting problem solved to. It fires up now immediately.
so at was just not enough amps to get it going.
case closed!
i think i need to look at distributor too as it makes quite a ticking noise.
...i do have a new challange :-( leaking coling fluid dripping of the fywheel house. Looks like comming from back side of block. Difficult to see as head board is very close to engine. There is one hose pipe there ..or gasket
