95 E320 Ignition Part Identification - Please Help!
Old Nov 15, 2011 | 08:46 PM
Brudwich's Avatar
1991 500SL, 1995 E320 Wagon - 500e Conversion
I'm in the process of changing out the ignition switch in my 1995 E320 wagon and have run into some trouble after taking everything apart.
The ignition switch currently in my wagon has a plastic T-shaped piece in the center, but all of the replacement ignition switches I've found are missing that plastic T-shaped piece and only have a metal slot in the middle. Below are images of the difference I'm describing.
Has anyone else run into this problem?
What my ignition switch looks like:
What all the replacement ignition switches look like:
Old Nov 15, 2011 | 09:48 PM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
Is the plastic T-handle piece removable if you pull on it? Perhaps it is one of those things that needs to be transferred to the replacement part.
Edit: I checked the EPC and noted the two parts that interface to the actual ignition switch. They are a washer (17), part 124 462 14 75, and the parking pawl (8), part 124 460 01 75. I also noted the the original switch (11) , part 124 462 03 93 has been superseded by 202 545 01 04. It may be the newer switch has the slot instead of the T-handle piece and so requires the change out of one or both of the above.
Attached Thumbnails 95 E320 Ignition Part Identification - Please Help!-ignition2.jpg
Old Jan 11, 2012 | 03:18 PM
vitop's Avatar
2006 E320CDI, 2012 E350 Bluetec, 2013 E350 Bluetec
I am dealing with the very same issue. How did you resolve it? I don't think the center comes off.
The pawl is a different part
Old Jan 11, 2012 | 06:05 PM
whipplem104's Avatar
1990 300ce supercharged and intercooled
It is not necessary. All the new ones come without. It just prevents it from being unplugged with the key off.
