First pick and pull experience and some trim questions
1987 300E, 1995 C280
Although 2 of the things i bought didn't work, and 2 things i bought i didn't need, i ended up spending $30
almost new strut mounts
outside temp gauge - light doesnt work
headlight switch
convience relay i think it was the one in the rear fusebox starting with 201 -no result change
got some wood trim - i don't need
steering wheel (decent shape)
some switches
so i was wondering if wood trim from e320 is the same as 300ce, same with the regulators.. i tried putting trim my 87 300e, doesn't seem to fit, or maybe i can swap out the 12v? although my ce uses a 3 pin switch and the 300e uses something else...
headlight switch
some switches
