1994 E420 white/ gray San Jose, CA $1900
1994 E420 White ext Gray Int
368,xxx miles. YES, 368K.
Interior looks fantastic for its miles. Exterior is also great for its mileage, no clear coat peeling or rust.
Clean CA title, title in hand.
Replaced front rotor and pads less than 500miles ago. A/C blows cold, same key for all locks. Starts up everytime.
Things that need attention, Price reflects what needs attention.
1) Passenger side front window does not work, I opened the door card. Window regulator needs to be replaced.
Window switch is good, window regulator motor is good and working.
2) Water pump is leaking from Cooling Water outlet. I have an exploded PDF, photobucket won't let me link the .pdf. I can sent the exploded view if you want.
3) Does not upshift to higher gear when WOT, could be full throttle switch. Transmission is good, all
vacuum lines replaced.
4) Idle hunts from 900 down to 500 RPM when cold. But idles fine when warm.
5) Smells like gas inside when cold.
6) sunroof does not open.
Car is currently registered till 12/2012.
Car is sold "as is" no warranty included or implied.
Car is located in near the Home Depot off Leigh Ave and Hillsdale Ave in San Jose.
Emails with no contact info will be ignored. This is a cash sale only.
No cash no problem, I will drive the car for you.
![](http://i1144.photobucket.com/albums/o489/darwinulep/2012-03-10203924.jpg)
![](http://i1144.photobucket.com/albums/o489/darwinulep/2012-03-10204023.jpg)
![](http://i1144.photobucket.com/albums/o489/darwinulep/2012-03-10204046.jpg)
![](http://i1144.photobucket.com/albums/o489/darwinulep/2012-03-10204121.jpg)
![](http://i1144.photobucket.com/albums/o489/darwinulep/2012-03-10204135.jpg)
