e320 ECU Wiring: transmission overload protection switch, clutch pedal switch, CO ...
Old Mar 12, 2012 | 02:27 PM
sagesingh's Avatar
W124 E220 carbriolet, '96
As some of you may know i am in the middle of changing my m111 to a m104. I have altered a bit of the wiring already to accommodate for the lamba sensor, gearbox wiring and another wire (that truthfully, i still do not know what it does, but its connected now and should be now problem).
The final issue i have now is the ecu wiring, there are 2 looms coming out of it, the engine harness and the other connects to the body harness.
I have a copy of the ecu pin out and there are 3 differences between the wiring harnesses.
The pinout diagram i have states that they are pins 9,22 and 23, which are transmission overload protection switch (TOPS), 22 is cruise control on/off (for 220 engine) and clutch pedal switch (for 320 model). Pin 23 is CO Potentiometer.
I have done some research and found that the TOPS has 3 wires going into it, i am sure that i can work them out with some more research but my issue is with the other two pins, 22 and 23.
Sorry if this is a stupid q, but what are/where are the clutch pedal switch and co potentiometer located?
this is the last hurdle and i want to get the car back on the road as the weather (in the UK) is picking up.
Attached Thumbnails e320 ECU Wiring: transmission overload protection switch, clutch pedal switch, CO ...-untitled.jpg
