Clunk from the trunk
Old Mar 30, 2012 | 05:39 PM
Whiskey124's Avatar
1990 300E
Whenever i take a turn that twists the chassis there is a loud clunk that comes from the trunk area. it seems to happen more often on left hand turns but does happen in either direction. any ideas??
Old Mar 31, 2012 | 12:10 AM
PaulX608's Avatar
2011 VW cc, 2004 ML350
Check your sway bar links. They are plastic which makes them cheap to replace but easier to break.
Old Apr 4, 2012 | 04:39 PM
Whiskey124's Avatar
1990 300E
just checked the sway bar links and they are both intact. still puzzled
Old Apr 4, 2012 | 06:09 PM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
- Check the rubber exhaust hangers - it could be hitting something if they are missing/worn.
- Check the remaining rear suspension links - are any damaged?
- Check the 4 rear sub-frame mounts - one or more may be broken.
- Check the two rear differential carrier bushings - I had a bad one of these and it clunked during acceleration/deceleration (like that which might occur driving the twisties).
- Did you remember to take the dead body out of the trunk? Seriously, check to make sure there is nothing lose back there, especially in the spare tire compartment.
Old Apr 5, 2012 | 02:03 PM
ALLDATAdiy INFO's Avatar
Former Vendor of MBWorld
Mercedes
Now that's funny! Is your Spare tire snug?
Old Apr 6, 2012 | 05:11 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
If your car has SLS, (I'm not sure it was even offered on a 300E), it could be your gas shock accumulators.
Old Apr 10, 2012 | 04:37 PM
BENZITCH's Avatar
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
Look at the flex discs on the driveshaft. They might be tearing.
