95 E320 oil light still on....
More specifically lower harness, lower harness, lower harness, lower harness, lower harness, lower harness, lower harness, lower harness, lower harness, lower harness. It's got the starter on it and goes to the + battery terminal. You'll see frayed wires by the oil filter housing.
UNLESS.... the bulb's in the wrong socket in your cluster and its really low coolant or coolant sensor. But inspect that harness first, no one changes that one when they swap out the upper harness but it has the same issue.
