Starting Problem
Old May 19, 2012 | 03:27 PM
CML4107's Avatar
1991 300E 3 Liter W124
Starting Problems with 1991 300E 3.0 Liter W124
Car initially starts and operates without any problem. Get get 2 miles down the road, suddenly run’s very rough sputters, bucks and stalls out. After many re-start attempts over 15 minutes, car starts, smoothes out and runs fine rest of day
Or pull into parking lot, shut car off car, returned 10 minutes later, car will turn but will not start even after many attempts. Leave car and return 20 minutes later, car starts right up and runs smooth again.
What's going on? Appreciate recommendations and suggestion(s).
Thank you in advance!
Old May 20, 2012 | 03:47 AM
neanderthal's Avatar
Start with a tune up.
Old May 23, 2012 | 11:43 PM
CML4107's Avatar
Starting Problem, 1991 300E 3.0 Liter W124
Thanks for the tune-up suggestion. Did several months prior to starting problem began. Replaced wires, plugs, rotor and cap.
Still don't know what's going on. Appreciate recommendations and suggestion(s).
Old Jun 1, 2012 | 12:08 PM
daratbastid's Avatar
1995 e320
do a fuel pressure test. I had extact same issues in a different car and it turned out it was losing pressure due to a bad pump
