SD Connect/Xentry
Old Sep 11, 2012 | 02:29 PM
ijonasse's Avatar
W210 E-class (E200 CDI)
Cool SD Connect/Xentry
Hi.
I've got a -95 W124 and would like to connect my SD Connect4 to it.
Is there someone here (I bet there is! :-P) who knows how to connect the wires from the mux? I've attached a .jpg which shows the color of the banana plugs.
The Black plug is of course ground, which will go in pos 1 on the Data Link
The White plug is marked KL15 which I understand is going to pos 16..?
The red plug is marked 12V B+, don't know where this goes.
The blue plug is marked K-Line/LIN, don't know where this goes.
There is to groups of plugs with two plugs in each. One Green and one yellow. One group is marked CAN HS and one is marked CAN LS. The green plug in each group is marked CAN_L and the yellow is marked CAN_H.
Anyone here knows the procedure on testing? :-)
Regards
Ivan
Attached Thumbnails SD Connect/Xentry-img_20120911_20030gfd2.jpg
Old Jan 4, 2014 | 04:37 PM
cataha's Avatar
w140 s420
Originally Posted by ijonasse
Hi.
Regards
Ivan
Try this link
http://www.benzworld.org/forums/5906504-post8.html
Old Jan 20, 2014 | 01:02 AM
LEISTUNG1's Avatar
Former Vendor of MBWorld
95 E320 Sportline/ 86 190E 2.3-16/ 05 C55
CONNECT YOUR BLACK, RED, AND WHITE PLUGS AS NORMAL RED TO BATTERY. BLACK TO GROUND OR PIN 1 SHOULD ALSO BE A GROUND AND PIN 16 IS KEY ON POWER FOR THE WHITE WIRE. THE BLUE WIRE IS THE ONE YOU USE TO COMMUNICATE WITH CONTROL UNITS. LEAVE DISCONNECTED UNTIL YOU SELECT VEHICLE AND HHT WINDOW WILL OPEN. THEN WHEN YOU SELECT WHAT CONTROL UNIT YOU WANT IT WILL TELL YOU WHICH PIN TO CONNECT THE BLUE CABLE TO FOR COMMUNICATION. THE OTHER 2 SETS OF GREEN AND YELLOW ARE NOT USED AT ALL FOR THIS.
