Headgasket blown...? advice needed.
Does anyone know if it is always neccessary to re machine the cylinder head after the headgasket has blown?
Also Is it neccessary to use the MB coolant or will any type do?
Thanks in advance
Jon.
Yes, you should have the head skimmed. No point doing half a job.
Considering the very small difference in price it's worth using MB coolant.
You should also consider changing the valve stem oil seals while you're at it as they tend to fail at around this mileage.
Here in the US we have available a cheaper antifreeze called Valvoline Zerex G 05 that has been recently approved by M-B for use on their engines. The formulation is nearly identical to M-B antifreeze.
Good luck.
Have the valve job done while the head is off. The real cost is in the labor, not the parts for this job. The machine shop will check the head for any warpage.
Use either of the approved anti-freezes.
Just went through this and the results were great.
Good luck,
chicago124
1990 300E 135k
