Shedding Real Tears over my Mercedes. Please help me-->
I have a '95 E320 Wagon that I bought for my wife as a 4th car. It ran rough on take off when I bought - chalked it up to a set of plugs. Seemed to moderately come out of it when engine is over 2k RPMs, but probably just spinning fast enough to seem like 6 cylinders.
New set of plugs - still runs rough.
Noticed the coil closest to the fire wall wasn't like the others..and also did a spark test to verify #6 is getting spark, #1 isn't. . like 1/2 the coil isn't working.
Bought a new coil - installed - still running exactly the same, still no spark on #1, but is on #6. . again like 1/2 the coil isn't working.
I know everyone that posts on every forum always says 'I've done the search and couldn't find anything', but I really have searched every possible search on Google, MB World, Benz World, Johnnys95E320misfires.com -and still nothing. I know about the plugs, coils, wires, harness, injectors and possibly crankshaft position sensor. . .
I'm asking if anyone has had a very similar situation and a remedy for it. Otherwise, the check the FS section in a few days for a ****ing part out of this thing. /rant
Just speculating, but a short circuit in the No 1 injector circuit could cause the ECU to shut down all signals - including the coil signal - to cylinder No 1 as a protective measure to preserve the ECU drive circuitry. Swapping the known good coils is the best test, but I think you will find that the known good coil does the same the thing.
Since you have an M-104 HFM-FI, I would suggest checking the ECU error codes as well. Search this board for how to make a cheap (under ten bucks) reader and read the codes.
