1995 E320 wiring
Old Nov 18, 2012 | 06:24 PM
mygr8star's Avatar
95 e320 cabrio, 89 420 sel, 91 300e
1995 E320 wiring
I had the dreaded wiring harness go bad on me.
I have it replaced, but the engine still stalls after coldstart within a minute or so.
I expect that the ECU might be failing or has failed due to wiring shorts.
Now: Can it be repaired?
I do have an ECU for a '93 2.8l eng from the junkyard. Could I run this one in my 3.2?
Might not be perfect but could I even try?
I think I have to rewire the trottle body actuator yet.
I hope someone can answer me soon. Thanks.
Old Nov 23, 2012 | 11:21 AM
Arthur Dalton's Avatar
E320 HFM
Check OVP relay part#.
Also, check codes @ pin 8 & 14
Old Nov 25, 2012 | 10:14 AM
mygr8star's Avatar
Thanks, could you tell me how I can chech the codes?
Old Nov 25, 2012 | 10:36 AM
You build a little LED tool.
Simple, cheap device.
http://www.peachparts.com/shopforum/...-pin-14-a.html
Make the tool and I will run you thru the process.
Old Nov 25, 2012 | 11:08 AM
mygr8star's Avatar
Arthur, mine has a push button and led build in . do I just need a jumper wire then?
Old Nov 25, 2012 | 11:18 AM
The built-in LED/SW will only address Emmisions fault codes stored in the N/59 DM.
[CE lamp activation module]
You want to get to the actual Engine Management/ HFM/SFI and EA/CC control modules.
That takes the tool and a different pin to activate the retrieve flash code format.
Here are those codes
http://www.autolib.diakom.ru/CARS2/p.../cs1000_mb.pdf
Old Nov 25, 2012 | 11:22 AM
mygr8star's Avatar
Ok, thanks. I'll whip something up and will be back for more advice.
