alarm on/off
Thanks!
First find the alarm horn in the engine compartment and check to see that both wires are attached. One is brown (which is ground) and the other is black with yellow stripe and pink dots (positive).
If they look in order, test continuity from the brown to a good ground location in the vehicle using a digital volt meter. If continuity is good, check continuity from the black/yellow/pink wire to the other end of that wire which is on one of the 2 plugs on the alarm module. Can't remember if that wire is on the smaller or bigger plug.. but there is only one with that color combination. You'll probably need the DVM and a long wire in order to test this one.
