High NO and HC on smog 94 e320
I've got a few questions about the m104 hfm, please chime in.
Story goes...
3 failed smogs...
first run(middle), not warm but also not cold catalytic converter.
second run(top), Cold cat, egr unclogged.
third(bottom), 3500 rpm for minutes so hot cat and tested right away, new O2 sensor.
Since last year, when it borderline passed, the only difference is a fan clutch. The engine is always 80C, as opposed to getting to 100C.
Somewhere in there a can of sea foam passed through the intake.
MAS sensor cleaned.
Cylinder compression is the same (175), plugs changed a year ago with copper, all read okay, even but on the rich side. Checked for spark, all strong. A bit of oil from the valve cover gasket; drops and not soaking to the top.
Harness good; runs like a champ, idles smooth, and start anxiously on the first crank.
Why is it rich? What tells it to dump fuel? The ecu temp sensor(new 1 year ago)?
Air filter is new. It received a lot of maintenance parts over the past year but smog is still the same. Cat seems good. Everything is pointing to running very rich at idle...
Thanks for the input!
For $12 and a guarantee to refund double your money, it maybe worth a shot.
I posted this on another post with a pic.
HTH
Omar
https://mbworld.org/forums/attachmen...smog-image.jpg
