Need some help with ignition coil problem
Old Feb 6, 2013 | 08:46 PM
EMAN171's Avatar
93 320E 3.2L
I Have a 93 E class with a 3.2L Just recently it started misfiring, I found that my Ignition coil for cylinders 2 & 5 not working, replaced coil but still no change, I even swap-ted one of the other coils and still no change it seems the coil is not receiving a signal , can anyone shed some light on this problem, I am thinking it might be the control unit itself
Old Feb 8, 2013 | 03:48 AM
EMAN171's Avatar
93 320E 3.2L
Up date; tested leads to coil and found current getting to the coil but still no spark, I swapted the coil from 2 & 5 location to the 3 & 4 location and coil works fine, something is just not telling the 2 & 5 coil to fire, all other coils and cylinders are fine, just can not figure what is it that tells the ICM which cylinder to fire, I thinking the cam sensor. Usualy when the ignition control module goes, all spark goes, I just can't figure it out
