W124 Noise
Old Mar 21, 2013 | 06:42 PM
Dysphoria's Avatar
'89 300CE
Exclamation W124 Noise
Hey guys.
Just need some help.
Basically I hear a knocking noise, to me, from the front of my car. Whenever I am in the parking lot and I'm slowly creeping around, I hear a knock noise or whenever I am slowing down to a stop. In both occasions, I am on the brake but enough on the brake that I'm still moving slowly, not fast.
I was thinking either the front pads are knocking back and forth or my lower control arm bushings are gone. I don't hear it when going over a bump, I am leaving out the ARB bushings. I haven't had a good look @ it but I will soon.
Any help?
Old Mar 23, 2013 | 02:47 AM
ptoro01's Avatar
86 W124
Struts?
A single thud knock or repetitive knocking?
If it's repetitive and sounds friendly, i'd answer it...
Old Mar 23, 2013 | 03:45 AM
Dysphoria's Avatar
'89 300CE
Well if I continue to keep my foot on the brake but still slowly moving I can hear it knocking continuously. As soon as I fool brake it goes awake. I also do hear like a shuttering/howling sound too on my Left front
Old Mar 23, 2013 | 02:35 PM
ptoro01's Avatar
86 W124
Get the wheel off the ground, grab the tire and check for vertical and horizontal play. You likely have vertical movement, that can be A-arm bushings.
Horizontal play is likely tie-rods.
Check struts for leaks.
Do you get a clunk when going over the curb turning into parking lots.
