1994 E420 Climate Control
Old Apr 20, 2013 | 05:08 PM
jcjcrespo's Avatar
1982 300 Turbo Diesel, 1994 E420
Greetings fellow W124 owners,
Had heated air coming out of side vents so, based on what I've read on this and other fora, I took a chance and replaced the mono valve; nothing changed. Checked voltage at mono valve connector and found Bat voltage at both wires; no ground on Yellow/Green wire at mono valve connector with A/C ON. Could it be a bad CCU? Any way of testing it?
