Poor idle 1986 300e
Old Apr 27, 2013 | 09:53 AM
Benzbit's Avatar
1986 300E
Poor idle 1986 300e
My '86 300e has a low idle. The engine shakes in gear at a light, otherwise the car runs strong.
I see Bentley's E-class Owner's Bible says to remove and ground the violet wire from connector 26/3 to increase idle by 50 rpms.
Where is connector 26/3 located?
Thanks in advance.
Benzbit
Old May 27, 2013 | 09:36 PM
Cartagena's Avatar
Have you checked spark, idle control valve???
Old May 30, 2013 | 04:37 PM
Benzbit's Avatar
1986 300E
Thanks, Cartagena.
I've solved my low idle problem by adjusting the EHA (electronic-hydraulic actuator) that is attached to the fuel distributor. There's a tiny hex nut under the screw on the EHA. The car starts and idles fine now after turning the nut a quarter turn to the right.
Benzbit
