89 300 E surging idle
A second problem is the interior heater/AC fan doesnt work, which is an unrelated (i think) problem and of course not as serious.
Any ideas on what it could be?
In my other searching outside this forum, I found that the problem may be the MAF sensor that is causing the surging idle. So I'll check that out this weekend.
I had exactly the same issue as described, the problem ended up being the throttle position switch.
Might be worth checking out.
I attached a photo and the part # i found for it was this:
0025456814
Switch; Thrust Cut-Off Micro-Switch at Throttle Linkage on Intake Manifold with Single Roller/Lever
By quickly looking at the throttle assembly, it's clearly visible. Most likely will have to remove the air filter to get a good look at it.
Also thanks for the tip on the blower relay, I'll check that tomorrow. I think also the wiper doesn't work now.
