1990 300E Transmission Clicking
Old Sep 20, 2013 | 06:42 PM
awagner's Avatar
1990 300E
I have 1990 300E and the automatic transmission makes a clicking sound when turning left. It only happens when turning left but it will happen while accelerating and decelerating. I can also feel the clicking through the shifter knob. Whats wrong and how much is my wallet going to cry?
Old Sep 23, 2013 | 03:34 PM
awagner's Avatar
1990 300E
Upon further examination it seems that there is something loose that can be felt when shifting into 3rd. What is down there that can become loose and how can i get to it?
Old Sep 23, 2013 | 04:00 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Put the car on a lift or jack it up and support with jack stands.
Check your flex discs both front and rear.
They are round rubber couplings with bolts through it.
Rubber can wear and bolts can pull through/loosen.
They connect the transmission to the drive shaft and differential.
Ed A.
Old Sep 23, 2013 | 04:13 PM
awagner's Avatar
1990 300E
The flex discs have already failed and i replaced them. This clinking is from where the gear lever meets the transmission
Old Sep 24, 2013 | 08:43 AM
RBYCC's Avatar
Probably the rubber bushings in the shifter linkage:
http://www.peachparts.com/Wikka/W124ShiftBushings
