94 e420 : Failed Smog. Please HELP
Old Oct 10, 2013 | 01:35 PM
chance2benz's Avatar
199o 300E, 1993 300E, 1994 E420, 1997 Range Rover 4.6
Please HELP- 94 e420 FAILED SMOG Again
My 1994 e420 keeps Failing NV Required Smog Test: for the third time.
So far I have changed spark plugs ( Bosch F8DC4), spark plug wires, 2 New Bosch dist. Cap. New Bosch rotor(2), coolant level sensor, coolant temp sensor.
Here are my test results,,,,,,,,,
Test Parameter. Result. Additional info.
Idle speed CO. 9.99 %. Greater than 1.2 %
High speed CO. 8.24 % Greater than 1.2 %
Idle speed HC. 671 Greater than 220 parts per mill.
High speed HC. 425 Greater than 220 parts per mill.
Also; the smog check " technician" says engine is getting 'way too much fuel' pumped into the engine - so much so that it is also causing a "Misfire" because of Excessive fuel.
OK guys: Please Help, Advise what to repair, replace ; as I really Need to at least PASS smog test !!!!!!!
THANKS ALL for Help, Suggestions, Recommendations etc. Chance
Old Oct 10, 2013 | 02:47 PM
ptoro01's Avatar
86 W124
Well with those numbers the check engine light is probably on, what codes are you getting?
Excess fuel is in relation to air and spark, if you don't have enough air, no matter how good of spark, it won't burn.
Have you checked compression?
Vacuum leaks?
Test if your O2 sensors are good.
Old Oct 21, 2013 | 08:13 PM
MB300te91's Avatar
1991 300te with a 95 front end facelift
I just went thru a rough ordeal with my 91 300te passing smog It just passed smog this morning. I first fail with high meas. all across the board for" calif meas." I replace the cat. first then I retested again and failed, but some meas. drop O2 and some others an all, but I still had high Noz. found after a few test vacuum did not engage EGR then found out a solenoid was bad that turns on the vacuum. after fixing that my EGR valve had a hole in some where. It would not hold a vacuum pressure.
Old Oct 24, 2013 | 10:31 PM
clarkz71's Avatar
1993 400E
Unplug the MAF, that will put it in default mode.
If it runs better, the MAF is bad. Quick, easy test.
report back if that doesn't help, I have more info.
Old Nov 3, 2013 | 12:32 PM
Onash's Avatar
95 E320 Cab (new toy), 06 Range Rover (Hers), 97 Ferrari F355, 05 Ariel Atom 2 (the other toy)
For what it's worth, my 95 failed miserably (I posted the numbers previously). The magic to passing the smog check CRC Guaranteed to Pass. Search my previous postings. It is $12 and they will pay you double back if it doesn't pass as long as the CATS are ok. It worked for me.
Worth a try.
