::ECS Tuning:: Propeller Shaft Flex Disc Kit For Your 300E
Former Vendor of MBWorld
2012 SLS AMG
Click HERE to order or for more information.
Kits Starting At - $111.64*
These propeller shaft flex disc kits for your Mercedes-Benz 300E include both the front and rear flex discs and all installation hardware.
Flex discs are a crucial component of the driveline, and their failure will not only leave your car immobile, but can also cause serious damage to the chassis and driveline.
Don't take chances on soft, cracked, worn out old flex discs; replace them today with a flex disc kit from ECS Tuning.
*Price subject to change.
got a kit for the C32?
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
What is the material specification of the 124 flex disc ?
How much difference in material spec compared to the OEM part?
Ed A.
Ed A.
92 500e, 95 E34 525I Touring
I wouldn't trust a $50 flex disc with my life. Especially when OEM SGF can be had for about $90 each. That is, unless you can provide some build specs to attest to the quality of your item.
Uro parts makes a unit that doesn't last 500 miles before it disintegrates. This is especially hazardous on mercedes as they often have an airbag sensor near the driveshaft and a damaged flex disc can activate the airbag without notice while on the highway.
2012 SLS AMG
Everyone -
These are OE replacement flex discs, made by well known manufacturers.
The kit that is on our site for $111.64* includes front and rear flex discs, and both are made by Lemforder.
Lemforder Flex Disc Kit:
The other kit, which is on our site for $115.90* includes the front and the rear flex discs. These discs are both Genuine Mercedes-Benz products. They are the same flex discs you would be buying from the dealership, and for significantly less than you would expect to pay from most dealerships.
Genuine Mercedes-Benz Flex Disc Kit:
