Help name this abnormal engine sound?? - Thanks
2001 c320 - 2002 ml55 - 2011 c300 - 2014 slk350 - 2015 cla45
Hello-
I have a funny sound upon start up on my 1994 e320.....
Hopefully the link below works.
Thanks in advance for any help!!
Upon cold start up my car makes this abnormal motor boat- put put type of sound. It last for maybe 4-5 minutes until the car is warmed up and then it stops.
Any ideas?
https://www.dropbox.com/s/3d3tx8sci0...G_2125.MOV.mov
Thanks again.
Any ideas?
Thanks again.
92 500e, 95 E34 525I Touring
That's the smog pump. It's normal for it to make noise like that, but usually it's not as loud. It sounds healthy, but I would check the hoses that route that air into the exhaust. They are prone to cracking from heat exposure and can leak that pumped air into atmosphere. Mine sounded similar to this when the hose was removed.
it has never been that loud.
will check the hoses!!
