Pulsating brakes
the pulsations can also be caused by dirt or rust in between the hub and the new disks. When exchange them you need to very, very carefully clean the hub faces and the new rotors (inside). Also check for burrs around the screw holes. New rotors can only be checked on a lathe not on the hub, since you measure the addition of all failures. If the distance between disk and pad is only fluctuating in one or two spots, it calls for non proper assembly. (did not forget the little Allen screw. to hold the disk??)
An other question is the brake cylinder/piston moving freely?.
The brakes were pulsing a little before this brake job, which is why I did all this in the first place. I'll have to check the hub for dirt, but it looked pretty clean on first inspection. What's odd is why the new rotor is pulsates worse than the old one, when I didn't even mess with the hub between exchanges. I also secured it with the allen screw.
Other than cleaning the hub, any more suggestions...
