Starter or starting?
is it the starter? or just what could it be????
thanks in advance
Gman91932
(where in old cars covered the carbeurator)
I hope you can help
-D
G
Once the starter starts the engine it should disengage from the flywheel by interruption of the current to its solenoid (bendix), if it continues to run on its own while disengaged it will certainly smoke itself as it is designed to run with a decent load in short bursts.
From what you have described, it sounds like you might have a faulty wiring harness that is now wet due to the car wash. You should be able to take a pressure washer to your engine and not have these kinds of problems (not true of later model MBs). I suggest that you take it to a qualified mechanic for proper diagnosis.
-D
I had never heard of such a thing as this. I hope I have helped someone by follwing this thread all the way to the finish.
