1995 E320 fuel system diagram
1995 E320, 1998 SL500
Any thoughts on where I could find a diagram/explanation of the fuel system for this car? From tank to injectors . . .
W124 E320 convertible 1995
Could this be of any help...?
I do not have your precise diagram. But again, you can look there:
http://www.mbpartsworld.com/showAsse...modelYear=1995
Thank you!
I will spend some time with your information. My car has two fuel pumps mounted side by side and I do not understand why the 2 pumps are necessary. Also, what I fear is that the mechanic installed the wrong pump.
I could understand if there was a low pressure pump in the tank and a high pressure pump feeding the injectors but both of these pumps look similar.
I have been supplied with a video of the pumps in a similar car.
