1994 E320 Wagon engine wiring harness
Old Mar 19, 2002 | 06:07 PM
bricknord's Avatar
1994 E320 Wagon
Question 1994 E320 Wagon engine wiring harness
Hi, all.
I am new to MBworld, new to Mercedes-Benz ownership.
I have just purchased my first M-B product, a used 1994 E320 Wagon in really clean shape.
It was traded in at the VW-BMW dealership where I work.
I love the car, and recently took it in to European Motorsports here in Kansas City to have a checkup.
Here is what they found, and I would like input from those of you in the know on the E320s, on what I should have done, how critical things are, etc. I am trying to maintain the car without spending my life savings, so I am trying to sort out what NEEDS to be done soon and what can wait.
1. I am told that a lot of the engine wiring harness insulation is brittle, and is pulling away at various connection points, creating a hazard. I have been quoted around $5-600 for the harness plus labor. I looked at a bunch of the connectors in the bay and I see what they are talking about. You can see small amounts of exposed copper at certain wire junctures. Is this some thing I can McGyver ( i.e. careful electrical taping of exposed areas myself) or is this critical that I have repaired?
2. Numerous minor oil leaks found. Front transmission seal leaks, lower section power steering gear leaks, both sides of differential output leak. Rear main hyropneumatic suspension valve wet. Quoted real high labor times, probably legit, to fix these various leaks. How critical are these?
3. Needs 4 rotors and brake pads ( 15% pad left).
Sorry for the long post. I would appreciate any feedback you folks may have, who have owned higher mileage ( mine at 121k) 300 series cars.
Thanks for the intellgent input.
Matt
Old Mar 19, 2002 | 07:39 PM
suginami's Avatar
93 300E
I have a 1993 300E 3.2, which is basically the same car with the same engine as yours.
Basically, all engine wiring harnesses on these 3.2 liter M104 engines are bad from 93-95. Here is a link with a great discussion on this issue:
http://www.mercedesshop.com/shopforu...iring+harness\
You really need to change this immediately. Common manifestations of a bad engine wiring harness are very numerous, but include and not limited to: various and random shorts in the electrical system; various, random, and meaningless engine fault codes; misfiring on any of the cylinders, an uneven idle, shorting out the ECU, computer, etc.
You really can't wait on this. Trust me. Letting this go can cause you thousands of dollars in damage. Your quote was right on. The wiring harness is $500 dollars and change, and the labor is 1-2 hours.
I have read many discussions between MB technicians on other websites, and basically two reasons for the bad wiring harness are noted:
1. MB tried out a new insulation to make the wires more recyclable or bio-degradable.
or
2. MB tried out a new insulation to make the wires resistant to rodents eating the wires.
In any event, it was a disaster and the insulation breaks down in the car. Many of these wiring harnesses were replaced by dealers under the original warranty or the Starmark warranty if the problem manifested.
As far as your other problems:
1. Various fluid leaks - I suppose these are just minor leaks, and can be tackled systematically one by one over time. Pick the worst one first, and then when you have the money, do the next one. Just check the fluid levels to make sure the fluid doesn't get too low. My buddy has a 95 E420, and just had his power steering pump rebuilt w/ new seals. The rebuild kit was $15.00. The labor was several hours. I'm very suprised your head gasket doesn't leak. The original gaskets leak oil at the right rear of the head. Replacement gaskets from the dealer seem to work without leaking.
2. Rotors and pads - MB rotors cannot be turned. The metal is very soft, and you will be replacing the rotors more often than other cars. Only use original MB or ATE rotors and original pads. Otherwise, your brakes will squeak badly. The rotors are available at the dealer for around $75.00 each, or you can buy them at mercedesshop.com for around $50 each. I would replace the front rotors and pads now, as they get the most wear. 15% pads left will probably last several months on the rear. Also replace the brake sensor when replacing pads. They're cheap. If you don't, your idiot light won't illuminate.
Don't let these repair / maintenance issues get you down. This car is 8 years old and probably has some mileage on it. Get the car up to speed, and it will give you many years of good service, and never show the wear that Japanese / American cars will.
People often say how expensive MB parts are, but in comparison, my Nissan Quest and Toyota Camry had higher parts cost on almost every similar repair I did. My dad's Buick also had higher parts cost for the rotors and EGR Valve than my MB.
Last, one other maintenance item to perform on these M104 engines is to have the hot inlet pipe to the intake manifold "reamed out" with a cable, like a speedometer cable and a drill motor. You may think I'm crazy, but this engine is notorious for engine fault codes indicating low egr flow. The average mechanic will send you on your way with a new egr valve, thinking that the egr was just closed shut. But the fault code will reappear. This hot inlet pipe gets clogged up with carbon from the egr vapors, restricting air flow. Many MB mechanics now include this on the 30,000 mile maintenance service. There is a great article on diagnosing engine fault codes at the mercedesshop.com website, I think under the DIY section, written by a master MB technician, 27 years, in Florida, that discusses this issue and how it was arrived at. The link to the article is here http://www.mercedesshop.com/diy_stevebfl_1.htm
Good luck, and let us know how you are doing as you tackle these problems.
Old Mar 19, 2002 | 08:06 PM
suginami's Avatar
93 300E
Here's another good link with a discussion of a 93 300E 3.2. (identical to your 94 E320. Why MB didn't change the name in 93 is a mystery to everyone..)
http://www.mercedesshop.com/shopforu...wiring+harness
Here's a link that talks about my problem with engine wiring harness:
Here's another thread about the engine wiring harness. M.B.Doc, an MB technician, suggests 2-3 hours labor for the job:
Another link, with picture that shows inspecting a wiring harness:
And another:
Old Mar 19, 2002 | 09:43 PM
suginami's Avatar
93 300E
I was checking the Mercedes Benz USA website for another matter, and stumbled onto a page that shows production numbers for each model year and original sticker price.
I was quite suprised how rare W124 wagons are.
In 1994, total U.S. production numbers for the wagon were 2,513, and the original sticker price was $46,200. Wow.
Here is the link:
http://www.mbusa.com/brand/container...24568&menu=2_2
Old Mar 20, 2002 | 06:20 AM
bricknord's Avatar
1994 E320 Wagon
Wow!
Suginami, thanks for the great info.
I feel better about things having read your replies. I got a little worried when I started looking at the list of issues and tallying up the $. However, long range I think you are right...get the car up to speed and then it shouldn't be too bad.
I appreciate the great info regarding the wiring harness. You have convinced me to have the work done asap on this one.
I will probably have all the brakes done at the same time, just because I am big on always having good brakes and tires ( safety). I try not to skimp on this kind of thing on any car.
I, too, found the sales numbers on the E320 Wagon for 1994 to be pretty interesting. Something like 2500 sold that year in the USA. Now that I think about it, I have not seen another one like mine in Kansas City ( silver-grey 2 tone with blue tex interior ).
Anyway, thanks a lot for the really informative response.
Matt
Old Mar 20, 2002 | 12:05 PM
suginami's Avatar
93 300E
I also recommend getting Michelin MXV4 Plus tires for your MB.
This tire is really the tire of choice.
I paid $137.00 each at the tire store near my house, but realized they are available at www.thetirerack.com right now for about $109.00 each. Cheap.
Old Sep 28, 2004 | 07:59 PM
larryrock's Avatar
Check Engine Light on 1994 E320 Wagon
I had the cable harness replaced several months ago (at a cost of $800!). since then the light keeps coming on. It's referred to around here as the "Spend Money Light".
I'm really frustrated. My car is currently getting its 120K Mile service and they want to charge another $650! to fix some sensor that monitors the "up shift O2 level(?). This is ridiculous!
Any ideas of what I can do, short of unplugging the light?
Old Sep 29, 2004 | 01:37 AM
349 BHP's Avatar
Mercedes E320 , Lexus IS350
thanks for bringing up this 2 year old thread!
those links are making me THINK
Old Dec 12, 2011 | 07:29 PM
Eric Cifarelli's Avatar
93 300te 4matic wagon, 94 S420
I am also experiencing electrical issue that I believe are the result of a bad harness. What have you guys found to be the least expensive way to go about changing it? I am willing to do it myself if necessary, I have replaced the harness in my acura mdx a year ago. It was quite an adventure but I did it well I must say. Any good advice will be appreciated.
Old Dec 12, 2011 | 10:16 PM
whipplem104's Avatar
1990 300ce supercharged and intercooled
Your car does not have the same harness. The '93 4matic has the older engine and the engine harness is part of the whole front body harness. Huge undertaking. What are your problems?
