power window switch failure
Old Feb 12, 2004 | 10:42 PM
brett's Avatar
2004 e320
Unhappy power window switch failure
my left rear window switch located near the gear shift isn't working. furthermore, it is not illuminating when i turn on my headlight switch. other switches are working fine and illuminating as well. When i use the switch on the door itself sitting in the back it functions properly. so the problem seems to be confined to just the switch itself. What should i do before i take this car to a mechanic?? could it be a fuse? or a lose connection? thanks
Old Feb 12, 2004 | 11:09 PM
Jer's Avatar
Jer
1994 E320
Could just be a loose connection. Remove the wood to access the switch.
Old Feb 13, 2004 | 08:44 AM
JoeR's Avatar
1987 300E
Having just "overhauled" 3 window switches in my daughter's '87 300E, I must say that I found that there is not much that can go wrong and that they are easy to fix.
What I found is that the contacts had become dirty and in some minor pitting took place.
To fix:
1. Open the console (single screw under carpet at rear).
2. Remove switch; lift out
3. Carefully open by popping off top rocker with a small screwdriver. (held at hinge; be careful.. there are two small *****)
4. Clean contacts (fine file or paper if necessary) and other surfaces.
5. Reassemble. Like new!!
Old Feb 13, 2004 | 09:53 AM
brett's Avatar
2004 e320
i dont want to screw up my wood and console so can you post very specific instructions on how to access this area.
Old Feb 13, 2004 | 10:55 AM
pifcat2's Avatar
300TE / 300E / 300CE
Pull up the rectangular carpet, it's a tight fit and slightly under the plastic surround. You'll see the two screws you need to remove. Then just pivot up that end up over the shifter. The other end is held by "hooks".
Old Feb 13, 2004 | 11:55 AM
Adobe's Avatar
This occurs to me on switches that I seldom use. I just keep working them until the problem goes away.
Old Feb 16, 2004 | 10:11 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Simple check for you switches is to take a good one out swap it with defective, then you'll see if the switch is gone. Right and left just has the top cover swapped, electrically they are identical. I "repaired" mine as one of the posters suggested. It worked for a few more weeks and then it was gone again.
Old Feb 16, 2004 | 12:37 PM
brett's Avatar
2004 e320
i followed the instructions and easily removed the wood trim to find the switch unplugged? it seems like it would take alot to unplug it but hey?? i plugged it back in and now all is working fine. thanks to everyones great advice. agiain this site saves me a bundle!!!
