Humming Sound
Old Feb 15, 2004 | 10:00 PM
jsolano's Avatar
Humming Sound
Help ..! Humming Sound
I was driving on the highway my 1993, 300E, and noticed a humming sound that never ended. I was thinking that it was a truck driving next to me, but when I looked around, there were no cars or trucks.
The noise comes from my car, it comes and goes. It may happen between (80 –120 km/h) or (50 mph-75mph).
What could be causing the noise?
PS: Current mileage: 72000 miles (115000 Kms)
Thanks,
Old Feb 16, 2004 | 10:14 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
check the cover underneath the engine, maybe it became loose, and starts vibrating at higher speeds. Check the tires for bubbles in the side walls. Check the transmission alignment with the drive shaft. Check the flex disks of the drive shaft.
Old Feb 16, 2004 | 04:48 PM
spsinha's Avatar
1994 E320 Coupe, 1979 500SLC, 2005 E55 - Sold
Check your wheel bearings, they may need to be tightened or replaced. They can often cause a loud humming/roaring noise at highway speeds.
Old Feb 16, 2004 | 10:28 PM
zeronero's Avatar
Mercedes-Benz 400E
Right now on my car I my smog pump bearing is going out and it's pretty loud. With the hood closed it sounds like a large amount of air is being forced through a small opening, like somethings blocking the fan. With the hood open the sound can be linked to the smog pump.
If you can try to locate the sound you might be surprised what's causing it.
Old Feb 19, 2004 | 07:37 AM
jsolano's Avatar
Still have not found what the problem is. It seems to come from the rear part of the car. I'll check the differential fluid tonight, I believe this is not the problem since I put new fluid last year, and it doesn't drip.
I took a look underneath, and how do I:
1) Check the transmission alignment with the drive shaft., and
2) Check the flex disks of the drive shaft.
What should I look for. Everything seems to be normal.
PS: The sound may start at 70 km/h, and increase/decrease it's sound frequency as the speed goes increases/decreases. I even put it in neutral on the highway, and the noise continued.
Old Feb 25, 2004 | 06:30 PM
jsolano's Avatar
I finally found out that my differential needed more fluid.
Added about 400 ml of differencial fluid and the problem seems to have gone away.
Thanks to all for your suggestions.!
