low coolant light.
Old Feb 17, 2004 | 02:09 PM
Ironzey's Avatar
low coolant light.
The low coolant light on my '89 300E have come on. It's not fully lit up like it does when you star the car, rather it's very dim. I checked the coolant level and it was a little low I added some more coolant but the light still comes on. There is no hint of overheating, it alway operates under 90 degrees. Everything else seems to be fine. This is still a relatively new car ,to me so I'm not aware on anything that seems out of order.
Old Feb 17, 2004 | 02:36 PM
spsinha's Avatar
1994 E320 Coupe, 1979 500SLC, 2005 E55 - Sold
Hello, its possible that the Coolant level sensor is not working properly.
Old Feb 17, 2004 | 06:13 PM
Daniyar79's Avatar
1992 Mercedes 300E
You need to replace your sensor. I had the same problem on my 92 300E. The light was on but it was very dim and sometimes it would even turn off completely. At first I cleaned the sensor but that did not help. Then I replaced the sensor and the problem went away.
Old Feb 18, 2004 | 12:40 AM
jsolano's Avatar
I had the same problem. Cleaned it up,.. did not work.
Unplugged it, and the light turns off.
I need to buy a new sensor.
Cheers.
Old Feb 18, 2004 | 11:31 AM
Ironzey's Avatar
Thanks I was hoping it was something like that.
