Axle seals
Old Mar 1, 2004 | 12:27 PM
Daniyar79's Avatar
1992 Mercedes 300E
Axle seals
My mechanic suggested I replace the rear axle seals and repack the CV-boots. Is that a DIY job or is it better to have the mechanic do the job?
'92 Mercedes 300E
Old Mar 2, 2004 | 03:42 AM
Arnie's Avatar
08 Lexus GS350 AWD. 08 Lexus RX350 AWD - wife's. 94 MBZ E320 - still have it.
Do your seals leak? If not, I wouldn't mess with them.
Normally the grease will stay inside the CV boots, unless the rubber cracks. Then if you run them dry for a while, replacing CV boots or repacking them will not help. You'll have to replace the axles, which is not that difficult.
Old Mar 2, 2004 | 11:02 AM
Daniyar79's Avatar
1992 Mercedes 300E
My mechanic said that the CV boots are drying out and my axle seals are starting to leak and should be replaced in the next 2-3 months. That's why I am trying to find out if I can do it myself or should I leave it to my mechanic.
Thanks.
