Oil Leak
1995 E320,2007 E350
Oil Leak
I have a 95 E320 that has developed a small oil leak. It seems to be coming from the area at the rear of the smog pump. If anyone can help identify what the problem might be it would be greatly appreciated.
Bennett Smith
South Carolina
Bennett Smith
South Carolina
This is a classic problem. It could be the head gasket or the lower gasket.
In any case, you have to find out which one has the leak and replace it.
Most people learn to live with it for a while and fix it when the engine needs an overhaul.
Good luck.
Good luck.
