Clear Corner Install
Old Apr 6, 2004 | 04:53 PM
Stack_Hardhouse's Avatar
2003 C32, 1999 E320 Wagon
Anyone have a link to instructions for installing clear corners?
Thanks.
Old Apr 6, 2004 | 05:48 PM
ZorroAMG's Avatar
Enzo, my Benzo
1) Open hood
2) remove light bulb
3) press tab on side of turn signals
4) pop out signal light
Revers order to install clear corner.
Old Apr 6, 2004 | 05:58 PM
Thanks for the reply, but for some reason it doesn't seem that simple on my car ('93 400E). I've tried fumbling around looking for those clips, but I can't feel anything.
Old Apr 6, 2004 | 06:13 PM
ZorroAMG's Avatar
Enzo, my Benzo
It IS that simple, all W124's are the same from 1985 to 1995, even 400 and 500e's. Maybe your clips are broken, in that case the steps will not help you, take it to the dealer they should be able to show you free of charge
Old Apr 6, 2004 | 06:46 PM
Holson's Avatar
18 G550, 24 EQB3504M
It's a little tighter around the 400E's engine bay because the cold-air induction is taken behind both headlights. Take some pieces off and look closer..
Old Apr 6, 2004 | 06:47 PM
Thanks for the help...I'll give it another try.
Old Apr 7, 2004 | 08:42 PM
I finally figured it out...had to remove the air intakes on each side. Thanks for the help.
