HELP. I have a grinding noise coming from the rear of my E320 95
Old Mar 12, 2017 | 03:29 AM
troylair1969's Avatar
500 SEL, 500SL, 500G
Angry HELP. I have a grinding noise coming from the rear of my E320 95
I am going crazy trying to find this most concerning grinding noise which sounds as though it is coming from the rear of the car. To date, i have done the following to rid myself of this grinding noise:
replaced brake pads,
replaced rotors,
new emergency brake pads,
changed the bearings,
changed the axel,
changed the bushings,
changed differential mounts and oil,
new tranny mounts,
new center bearing drive shaft,
new flex disc both front and rear,
and still this hateful grinding noise haunts me.
The car has 161K miles, never wrecked, i am the second owner. Prior owner was a Mechanic and took really good care of her. Please help, anyone. Please.
Old Mar 12, 2017 | 04:34 AM
swatty's Avatar
220SE Coupe, ML250, E320
Diff bearings ?
Old Mar 14, 2017 | 02:51 AM
ptoro01's Avatar
86 W124
Driveshaft support ?
Brake rotor shield rubbing on something ?
Describe the sound
Old Mar 14, 2017 | 04:05 PM
Question the grinding noise...
the shield to the rotors was removed, due to failure of the shield. but the grinding noise was happening before this was removed.
the noise sounds like brakes grinding, metal to metal. caliper on rotor yet the rotors and calipers are fine and no wear on the brakes.
any further thoughts come to mind?
Old Mar 16, 2017 | 12:30 AM
ptoro01's Avatar
86 W124
lug bolts are too long ?
Old Mar 16, 2017 | 02:12 AM
QVHK's Avatar
'90 300CE M103 Manual '93 Alfa 164 QV24 '05 Jaguar X350
Can the car be raised, and then tested with the wheels running to see where the noise comes from?
Old Aug 6, 2017 | 01:21 AM
Elshad's Avatar
MB 1994 E320
grinding sound from rear of E320 1995
Hello, did you find out what was the problem?
I have same grinding sound when I brake abruptly (when braking slowly at a lower speed sound does not appear). Also when I back up the sound comes on.
Same wise like you I have changed the brake pads but the sound is still there. Took it the mechanic, he said that that this is differential problem. A few words about the car: it is pretty neatly maintained, but has some moderate amount of rust underneath, for instance when I jack the rear to do some work (brake/tire) the central core of the frontal bushing separates from the whole part. I assume probably other rubber parts/rear bushing are degrading and may contribute to the problem.
Please let me know if you were able to find and fix the problem.
Good luck and kind regards!
