A/C Refrigerant Temperature Sensor RED
Old Apr 25, 2017 | 11:52 AM
Joe C.'s Avatar
1986 560SL, 1995 E320, 2005 E320, 1987 Ford Lariat F150
If I replace this sensor (see photo), will the w134A coolant leak out? Any advice or guidance would be appreciated. The car is a w124 (95 e320).
Attached Thumbnails A/C Refrigerant Temperature Sensor RED-img_0771.jpg
Old May 2, 2017 | 04:26 PM
Joe C.'s Avatar
I did some more research and the answer to this question is yes. The switch is under pressure.
Anyone have instructions on how I should go about replacing this? I suspect that I have to "drain" the ac system prior to removing the sensor. Any guidance or instructions would be appreciated.
