S124 300TE 1987 M103 dossent start when its cold or hot. only with starting fluid/gas
Subscribemy car dossent start without starting fluid/gas. when it runs it runs pretty great but it dossent idle i need to hold the gass pedal in.
i have changed petrol, fuel filter, washed the idle Control valve and changed the hoses too. and spark plugs from bocsh
i have checked for leaks With spraying starting fluid around and found a vacum leak at one of the injectores
Okey, the throttle body can be sticky some Time, is any Fix diy for that
Im not understanding. Sorry but im from Norway, its not many og us that know the k jetronic or this engine
May not be the same as your problem but see if the following threads elsewhere will help you pin down the issue:
http://www.mbclub.co.uk/forums/engin...ics-foxed.html
http://www.peachparts.com/shopforum/...g-problem.html
https://mbworld.org/forums/e-class-w...tor-issue.html
Joakim if you have leaking injector seals i would start there first .Check out all the small micro vacuum pipes and joints ..around the engine along with the fuses in the fuse box give them a turn in fuse holder. And check all earth points .All these help the starting up of the engine... The fuel distributor sits on a large rubber boot type seal .These leak through splits.. Do you have a manual ?
