DTC for 92 400E PIN7 code 11.
Old Jun 11, 2017 | 12:12 AM
Brian McL's Avatar
Anybody know what the remedy / cause is for a code 11 on pin 7 in this non ASR 400E 1992?
For this car it reads "closed throttle recognition signal to engine control mod....." What is the most likely cause of this error code?
Old Jun 11, 2017 | 03:39 PM
Brian McL's Avatar
WDBEA34EXNB696354
Old Jun 11, 2017 | 06:19 PM
Brian McL's Avatar
Thanks. Does this car have a switch on the gas pedal that works with the throttle body? Where is the throttle position sensor located? Do you know? Thanks again.
Old Jun 12, 2017 | 09:01 AM
Brian McL's Avatar
Thanks...is there also a switch attached to the gas pedal or brake pedal ?
