86 300E Won't Start
I have a orange spark, at least on one plug. I changed to an old distributor cap, but no start.
I hear the fuel pump activate for a second when I turn the key. The temperature sensor, crankshaft position sensor, and coil are within ohm parameters.
Starting fluid doesn't work, but the car seems like it wants to start when I crank the starter.
Appreciate any help. I intend to replace the distributor cap and rotor.
Benzbit
Bronson, FL
The old plugs were sooty and the car stumbled until fuel in the cylinders was burnt. I haven't been using the car except for short trips and around the property.
I wonder if I have an under lying problem such as a weak coil that's contributing to the filing of the plugs?
Benzbit
Benzbit
