Rebuilt engine...two questions...
Old Apr 27, 2004 | 10:43 PM
mila6062's Avatar
1990 300-E
Recently had a rebuilt engine put in my 1990 300-E. Since then, my radio antenna will not go up anymore, and the yellow windshield- washer light light stays on. Any suggestions on how to correct the problems?
Thanks,
Mila
Old Apr 28, 2004 | 12:16 AM
Jer's Avatar
Jer
1994 E320
How could the installers have screwed up these non-engine-related systems?
The windshield washer lamp might be on as a result of a loose connector on the level sender in the tank. Make sure the plug is firmly seated and the contacts are clean.
The antenna problems could be caused by a fuse (I think it is separate from the radio, so check first), or someone removed the radio and the DIN plug is not in order.
